Auto Login problems
Mav
Fixes: 514
Auto Login problems
Recently I have had to keep resetting Auto Login.
Each time I set it to 2 years as I understand from previous discussions larger amounts will cause issues.
Cookies are enabled and this has happened on FF 3.6, 4 and now 5.
After a reboot I often have to log back in again (I have not logged in on any other PC meanwhile) and the Auto Login page shows as Off.
Forum Moderator and Customer
5 REPLIES 5
adamwalker
Fixes: 221
Re: Auto Login problems
Sorry if this is something obvious that you've already tried but have you deleted your cache of cookies, temporary internet files etc?
Adam
 Adam Walker
Mav
Fixes: 514
I'll clear the PN cookies and empty the Temporay Interneyt Files and reset the Auto Login but this problem has even ported across a clean install of W7. (I mean just days after the clean install the problem appeared again.)
Oh, yes, I only ever use FF to access the portal.
adamwalker
Fixes: 221
want to try another browser just to try and rule that out as a cause of the issue?
 Adam Walker
jelv
Fixes: 10
Someone else going to vote for the chocolate fireguard?
http://community.plus.net/forum/index.php/topic,93852
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Mav
Fixes: 514
Thanks for the link jelv.
That just about sums up the issue.
PITA. I have logged in via IE8 now and set the Auto Login. A quick look back in FF I am still logged in but Auto Login is now off.
Back to IE8 and I am still logged in but Auto Login is Off  Crazy
