An error has occurred
Unlucky
I have had the same error on my account for a long time now, It just says "An error has occurred, You cannot make any changes to your account while there is a phone order in progress". I don't understand what this means but I do know I don't have any phone order in progress, I need to make some changes on my account but I can't with this error.
Tags (3)
9 REPLIES 9
Fixes: 382
Re: An error has occurred
@Unlucky Hopefully a staff member will pick this up tomorrow and correct the failure of the system which caused it.
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Broadband to My Account/Billing.
Forum Moderator and Customer
willcutforth
Fixes: 113
@Unlucky I have popped it through the system and it should be fixed today at some point.
 Will Cutforth
DebbieB
Hello. I'm having the same problem with this error message and want to renew my broadband but the error is stopping me. Thanks
grazuncle
I had this come up just after renewing (another story)
I thought it had messed up my account but it is clear today..
fistsbs
My account has the same problem after switching to full fibre.
James30
Fixes: 32
@DebbieB – Sorted, I’ve raised a ticket on each of your accounts to force the system to mend it. Just give it about 24 hours.
@grazuncle – Your account seems to be ok.
@fistsbs – You’re affected by another issue and I’ve left notes here @ https://www.plus.net/wizard/?p=view_question&id=239641345 with the ins and outs and I’ll check back in with you on Tuesday.
James - Plusnet Sheffield
grazuncle
My apologies..i only posted to show that you get the message when you change something.. didn't mean to give you extra work🤦🏻‍♂️
DebbieB
Thanks for sorting James!
