An error has occurred.
FIXED- Subscribe to RSS Feed
- My Account/Billing
- An error has occurred.
09-01-2020 3:17 AM
An error has occurred You can't change your products for the moment, you have an order which is currently being processed. Please try again later.
Or get the message:-
You're ahead of the game
I have not made any orders since I joined PlusNet over a year ago please can you look at this for me so I can use my account section to complete the offer that I see in the renew message, thank you
Fixed! Go to the fix.
09-01-2020 6:50 PM
Re: An error has occurred.
09-01-2020 8:33 PM
i've got exactly the same problem
kev
09-01-2020 8:40 PM
@wesc2 this looks to be sorted too now. Please check and let us know if you see any problems.
09-01-2020 8:51 PM
09-01-2020 9:53 PM
10-01-2020 9:20 AM
10-01-2020 11:47 AM
13-01-2020 12:19 PM
13-01-2020 5:03 PM
13-01-2020 5:15 PM
Thanks for the screenshot @dougs
Bit of an odd one you've got there, I've been looking into this with a colleague and we can't see anything which may be causing this. I've raised this over to our NetOps team for further advice and I'll let you know when I know more.
In the meantime is this stopping you from changing your products/are you wanting to change your products?
19-01-2020 12:06 PM
i have the exact same thing 😕
20-01-2020 11:59 AM
Thanks for your post @timc1984
I've sorted that out for you now, let us know if there's anything else you'd need help with
26-01-2020 12:28 PM
Please fix my account also.
"An error has occurred
You cannot make any changes to your account while there is a phone order in progress."
No there isn't.
Had this problem for many many weeks. I'd like to see my upgrade options. Support via phone has fobbed me off several times. One of your sales reps (having a bad day??) suggested I change provider??! 🤣
26-01-2020 3:32 PM
Thanks for your post @HMX
I'm sorry to see you're also having issues with this. Unfortunately this is relatively similar to @dougs issue I've been unable to fix however I'm endeavouring to raise this for further investigation and any extra examples such as your own will greatly help.
For now I've not got a solution or a timeframe when this will be sorted. While you'd be able to discuss a fibre deal with our customer options team on 0800 013 2632, the problem is impacting our ability to change your product too.
As a workaround, I'm adding a reply on to your support ticket 198218814 which I hope helps.
