An error has occurred.
Belucky
Hi Recently on my account there is a message telling me it’s time to renew and every time I click the link I get a message that says:-
An error has occurred You can't change your products for the moment, you have an order which is currently being processed. Please try again later.
Or get the message:-
You're ahead of the game
I have not made any orders since I joined PlusNet over a year ago please can you look at this for me so I can use my account section to complete the offer that I see in the renew message, thank you
77 REPLIES 77
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: An error has occurred.
I've had that fixed for you.
An order was showing as not complete on our database causing the issue. It should be right now.
 Tony T
wesc2
i've got exactly the same problem
kev
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
@wesc2 this looks to be sorted too now. Please check and let us know if you see any problems.
 Tony T
wesc2
Yes working thanks for the fix
Belucky
Fixed 👍 thank you
ozimsdz
@plusnettony can you please fix the same issue in my account?
dougs
Fixes: 1,600
@ozimsdz Unfortunately this is a different issue on the back of This. We're working to fix this as soon as we can. Apologies for the inconvenience this causes.
@dougs I can't see anything wrong with your account, can you post up a screenshot showing the error?
dougs
Fixes: 1,600
Thanks for the screenshot @dougs
Bit of an odd one you've got there, I've been looking into this with a colleague and we can't see anything which may be causing this. I've raised this over to our NetOps team for further advice and I'll let you know when I know more.
In the meantime is this stopping you from changing your products/are you wanting to change your products? Smiley
timc1984
i have the exact same thing 😕
Fixes: 1,600
Thanks for your post @timc1984
I've sorted that out for you now, let us know if there's anything else you'd need help with
HMX
Please fix my account also.
"An error has occurred
You cannot make any changes to your account while there is a phone order in progress."
No there isn't.
Had this problem for many many weeks. I'd like to see my upgrade options. Support via phone has fobbed me off several times. One of your sales reps (having a bad day??) suggested I change provider??! 🤣
Fixes: 1,600
Thanks for your post @HMX
I'm sorry to see you're also having issues with this. Unfortunately this is relatively similar to @dougs issue I've been unable to fix however I'm endeavouring to raise this for further investigation and any extra examples such as your own will greatly help.
For now I've not got a solution or a timeframe when this will be sorted. While you'd be able to discuss a fibre deal with our customer options team on 0800 013 2632, the problem is impacting our ability to change your product too.
As a workaround, I'm adding a reply on to your support ticket 198218814 which I hope helps.
