Allowance usage
- My Account/Billing
- Allowance usage
Allowance usage
11-09-2012 10:05 AM
I been with Plus Net for last about 7/8 months. I have started with basic package including free calls and Broadband of 10gb. I have at least 4/5 computers running at my home and using internet daily. Main usage are normally in evening and weekend. Every month I over use my broadband allowance. I am well aware about it. in last 6 months I been using around 35 gb allowance. So I thought I better upgrade to more rather then paying extra each month. I called Plus Net, very helpful they have upgraded my line to 60 Gb a month. My standard usage of 35 GB gone up within a month by another 25GB. Now I been using over 60GB of internet and downloads. Nothing has changed is still 4/5 computers, internet usage of streaming of music or watching movie, email checking and some odd downloads of attachment. same as before and suddenly gone up by more then over 20GB a month. Is there any way I can check what are my usage is?
Message 1 of 3
(1,229 Views)
2 REPLIES 2
Re: Allowance usage
11-09-2012 10:08 AM
Welcome to the forum Glasswater
You could install Networx on all computers.
Message 2 of 3
(349 Views)
Re: Allowance usage
11-09-2012 11:40 AM
Hi Glasswater,
As Strat says it might well be worth installing Networx as that'll let you monitor the usage of each computer it's installed on.
If you're interested in extra usage on top of the 60GB it'd also be worth looking at http://trials.plus.net - there's an option on there that might well tempt you
Hope that helps.
Hope that helps.
Message 3 of 3
(349 Views)
