Additional usage
- My Account/Billing
- Additional usage
Additional usage
11-09-2011 4:26 PM
I just want to check how the additional usage thing works.
I've done a lot online this month so am approaching my limit quite early on. I understand that anything over the limit is charged at £5/5GB, and I can set my own limit on that. What I want to check is: do I actually have to set a limit in order to "activate" or authorise the extra payment? There is currently no limit set, so will I just be automatically charged for each extra block of 5GB I use, or will my speed be cut until next month unless I set a limit?
Message 1 of 4
(1,100 Views)
3 REPLIES 3
Re: Additional usage
11-09-2011 5:10 PM
If there is no limit set then they will keep adding 5GB blocks for ever
Message 2 of 4
(336 Views)
11-09-2011 5:55 PM
thanks
Message 3 of 4
(336 Views)
11-09-2011 6:18 PM
but if you go over at 2 minutes to midnight on the last of your days, it will add 5G and it doesnt carry over
Message 4 of 4
(336 Views)
