Adding usage to current month?
breakat
Hi, i want to add some gigabytes to my current months usage. I can't seem to find where this is done. I see this https://portal.plus.net/data_transfer_watch/ , but it says don't change till end of month.
Any help please?
Fixes: 63
Re: Adding usage to current month?
That's the correct place to make the change.
The message does seem odd but what I think it means is not to set the value smaller than you have already used for the current month. Waiting until the next month starts will avoid problems doing that will cause.
However in your case I think you are safe to increase the setting to what you need.
David
breakat
Cool. Thank you!
