Account downgrade
happybunny
Account downgrade
Hello Plusnet
I’ve just received an email telling me my product has been incorrectly applied as a 80/20 and you will change it to up to 38.
I’m on a legacy 55/10 product and wish to remain on this.
Please can you correct your mistake.
5 REPLIES 5
Fixes: 1,600
Re: Account downgrade
Hi there.
From what I can see while the profile on your account is set at 55mbps you're still provisioned on 80/20 from long ago.
I've placed an order to modify your circuit to 55/10 which should go through tomorrow. I've also e-mailed the project owner as a heads up asking to take you out of the automated process.
happybunny
Thanks @Gandalf, appreciate the quick response and action.
Fixes: 1,600
No problem and I've just had a reply back from the project owner advising that you've been taken out of the automated migration work. Thumbs_Up
happybunny
Great.
The modified profile has applied and is reporting correctly my end
Fixes: 1,600
That's good to see! Let us know if there's anything else we can assist with.
