way to improve signal indoors?
Brownman
Is there a way to improve signal indoors at my location so I can get 3g coverage? I don't want to use wi-fi but the coverage I am getting is very hit and miss (more miss) despite the coverage map saying it would be good indoors?
Many thanks
2 REPLIES 2
Gel
Aspiring Champion
Fixes: 27
Re: way to improve signal indoors?
See if a friend's phone, using same network, does better. If so, buying a different handset may do the trick.
Smith7
Seasoned Pro
Welcome to the Forum
If you put your postcode and then your address into this link you will see if you should be getting a good EE signal coverage
If it shows EE is poor you will what other providers are good
I find it useful
 https://checker.ofcom.org.uk/en-gb/mobile-coverage
