sending text says "message not sent - phone number formatted incorrectly"
ekimrob
Hi ,
Can anybody advise me what I need to do to fix this issue
I am on Plusnet Mobile.
The text number is just a  5 digit text which is where it was sent from..
Thank you for any help
Mike
1 REPLY 1
Mr_Paul
Seasoned Pro
Fixes: 11
Re: sending text says "message not sent - phone number formatted incorrectly"
@ekimrob
AFAIK, Plusnet Mobile does not support these 5 digit numbers and there is no "solution" for this - other than changing networks.
