"This person's mailbox is disabled"
llew67
Hello. I have realised that my mailbox is no longer working - some months I believe.
All callers to my mobile get the message "this person's mailbox is disabled' ... upon 'busy' or 'no reply'
I have checked handset settings and find 'forwarding' settings 'upon busy' and  'no reply', are both forwarded to 07870020555 correctly?
Have searched the forums to find other similar instances but with no resolutions shown.
PlusNet have turned voicemail off and on again - SIM card cleaned - mobile reboot numerous times - all to no avail.
Can anyone help please. I'm stuffed.
4 REPLIES 4
Fixes: 1,466
Re: "This person's mailbox is disabled"
Moderators Note
This topic has been released from the automated spam filter.
Fixes: 1,552
Hi @llew67
I’m sorry to see your voicemail’s not working. Have you tried dialling 555? There should be an option to select which enables the mailbox.
llew67
Thank you Thank you! I dialed 555 as you requested and worked the option to enable mailbox. Mailbox is now working.
Fixes: 1,552
Excellent! No problem and thanks for the confirmation @llew67 let me know if there’s anything else you’d need help with Smiley
