"Call Ended" + Beep but no Engaged tone, when phone being called is engaged
geoffers
I expect this has been reported before, (but couldn't chose the right words to find it...)
I'm trying to call a heavily used number which is constantly engaged, but don't hear the engaged tone - just get a beep & "Call Ended"
If I call using my BT landline I do get the engaged tone as expected, so there's nothing wrong at the other end (except they're busy)
Any ideas ....
Thanks, Geoff
7 REPLIES 7
alan659882
Re: "Call Ended" + Beep but no Engaged tone, when phone being called is engaged
Yes, I get the same, it's been like that for a while and it's really annoying.
I have a dual SIM phone, if I call using my O2 SIM I get a few seconds of engaged tone and the message "Line busy" on the screen.
corringham
Seasoned Champion
Fixes: 16
Yes, this is a recurring problem that has been reported here several times. My household has 3 Plusnet phone SIMs, and probably 50% of the time we can't make or receive calls. Making calls gives "Call Ended" immediately, and we get missed call notifications even though the phone never rings. This happens even when the called phone is not engaged. The signal is full strength, and my work EE phone never has this problem. This is with 3 different SIMs and phones, so it seems to be something specific to Plusnet rather than a particular phone, or EE as a whole. Plusnet have never even acknowledged the problem.
Now that good deals are available from other providers I'll be migrating away.
Wadoadi
We get this issue too two phone same issue! also, a friend on Plusnet in a different part of the country gets it too. I have reported it in the past but it is not accepted as an issue. think I will look for another provider!
I assume they are running out of network capacity on the virtual network!
goldenfibre
Seasoned Pro
Fixes: 12
FIXED: VoLTE calls enabled - no ringing out VoLTE calls disabled - ringing out
Wadoadi
Most of the time it works fine it's only one or two days or so a month on average and only a few hours on that day! it also inbound, not just outbound. inbound goes directly to answer phone. also when I have the problem so does another phone in the same house and often a friend some 4 hrs away will message me to ask if I have the issue when he gets it. Mobile data continues to work fine both inbound and outbound stop working!
jimwin
I am having the same problem, I have dual sim phone and this does not happen if I use Giffgaff.
I notice no one has come up with a fix.  I must say it seems to have only started happening in the last six months or so, probably after a system update but not sure if that is the cause.
Wadoadi
I gave up and left, been on Smarty for some months now not had one issue!
