charged for calls/texts under roam like at home
callerwaiting22
I have been charged for calling and texting Irish mobile phones while in Ireland. I thought this was covered under my contract as roam like at home. Have I misunderstood, or been mischarged?
5 REPLIES 5
Fixes: 154
Re: charged for calls/texts under roam like at home
RoI is in international band 1 - see here Roaming and international calls | Help | Plusnet
Band 1 is marked with a dagger (†) ...
"Where no charges are listed above, these services are included within your mobile plan allowance. Once you have used all of your allowance, you will be charged the same charges as when you are in the UK. These charges can be found in our Mobile Price Guide."
That seems to suggest that unless you have exceeded your allowances there is no charge for calling RoI numbers from the UK and therefore infers that calling RoI numbers when roaming like at home, in RoI should also not be charged if you have not exceeded your allowance.
Clearly a staff response is required for an affirmed interpretation of the rules.
willcutforth
Fixes: 95
Hey there @callerwaiting22 can you send over your mobile number and name via PM and I will have a look into this for you? What @Townman said is correct so I just want to make sure nothing has been exceeded.
 Will Cutforth
callerwaiting22
Hi @willcutforth - I get an access denied message when I try to PM you via this platform. Is there another way to get my details to you please?
Fixes: 383
@callerwaiting22 to get PM privileges, you need to have either made 5 posts in total  or 3 posts and have logged in twice for at least 10 minutes. So another reply to this thread will probably be sufficient
callerwaiting22
Super, thanks @MisterW
