Will my phone work in New York ?
Zelda5289
Hi, I'm going to New York in 4 weeks. Will my iPhone with plusnet sim work ok whilst there or do I need to do anything to make it work?
Also if someone texts me from England or if I text them, will it cost them anything? Thank you!
2 REPLIES 2
Mads
Fixes: 79
Re: Will my phone work in New York ?
Hello @Zelda5289,
Thanks for getting in touch us!
Your service should connect onto the local network over there and work as normal. As its outside the EU you will find that you will be charged outside your normal tariff for any calls and texts you make or data you use.
You can find more information on the charges for making receiving, and using your services here: https://www.plus.net/help/mobile/roaming-and-international-calls/.
Hope you have a great time in New York!
Fixes: 339
It won't cost them any more than it would normally if you were in the UK, it WILL cost you to receive calls though. Check Maddy's link for costs , it's not cheap! Beware using any data when roaming in the USA it's eyewateringly expensive!!
