Will This Cheap Phone Work with PN Sim Card?
sue_h
I'm thinking of buying a cheap phone from china:  ASUS ZenFone Pegasus 4A ZB500TL Daul Back Camera Android 7.0 Unlocked
2G: GSM Band 5/8/3/2
3G: WCDMA:Band 1/2/5/8; TD-SCDMA: Band 34/39; CDMA 2000:BC0
4G: FDD-LTE :Band 1/3/5/7; TD-LTE :Band 38/39/40/41
Will this work with the PN sim card?
Sorry, I haven't a clue.
Sue
7 REPLIES 7
firebird1000
Re: Will This Cheap Phone Work with PN Sim Card?
hi there i have a mobile phone from china and the plus net sim card works fine in it my one is a duel sim so i can use 2 sims in the one phone Smiley
Fixes: 341
@sue_h
This link https://www.4g.co.uk/4g-frequencies-uk-need-know/ gives useful information as to the bands(frequencies) used by the UK operators. PN use the EE network.
That phone doesn't support LTE(4g) on Band 20. Whilst it will still work on PN since currently they don't have access to Band 20.
However Band 20 gives the best 4g coverage (since it's a lower frequency) and so, should PN get access to that band in the future, or you change to another operator which does use Band 20, you would not be able to take advantage of the better 4g coverage.
sue_h
Thanks for the replies guys.  That has really helped me out.
Just wanted a cheapy so have forgotten the ASUS one and gone with a Galaxy S5  Not the latest but it's new and I want it to make calls mainly.
firebird1000
Asus ZenFone 4 Max HD ZB500TL Smartphone Full Specification
  • GSM / UMTS / LTE GSM / UMTS / LTE
  • 3G Support
    Yes Yes
  • 4G Support
    Yes Yes
  • 2G Network Bands
    GSM : 850 / 900/ 1800 / 1900 MHz
  • 3G Network Bands
    UMTS : 850 / 900 / 1900 / 2100 MHz
  • 4G Network Bands
    LTE : 700 / 800 / 850 / 900 / 1700 / 1800 / 2100 / 2600 MHz
    LTE-TDD : 1900 MHz (Band 39)
    LTE-TDD : 2300 MHz (Band 40)
    LTE-TDD : 2500 MHz (Band 41)
    LTE-TDD : 2600 MHz (Band 38)
  • SIM Card Type
    Nano+Nano/microSD Nano+Nano/microSD
  • Number of SIM Card
    2 2
  • Dual SIM Support
    Yes with Hybrid Dual SIM support Yes with Hybrid Dual SIM support
firebird1000
hope my last post sorry should have been
Asus ZenFone Pegasus 4A ZB500TL Smartphone Full Specification
this has the same spes ps my china phone with the same specs works on plusnet 4g which is ee the provider
Fixes: 341
@firebird1000 whilst your link claims that the phone does support LTE Band 20, other links such as http://phonedb.net/index.php?m=device&id=11750&c=asus_zenfone_pegasus_4a_dual_sim_td-lte_cn_zb500tl  and the OP's first post suggest it only supports 1/3/5/7 .
This site https://www.frequencycheck.com/carrier-compatibility/09EYTJd/asus-zenfone-pegasus-4a-dual-sim-td-lte... is useful and seems to confirm a lack of Band 20 support
sue_h
Thanks guys, my dopey question turned out to be informative with the very useful links.
I've gone with a Galaxy 5S  It either works or it doesn't, PN sim card doesn't tie me up in a contract so I really have nothing to lose apart from a few quid.
