Will Plusnet 4G SIM work in a Nokia Lumia 530 (3G mobile phone)?
- Mobile
- Will Plusnet 4G SIM work in a Nokia Lumia 530 (3G ...
19-01-2017 6:31 PM
Will a new Plusnet 4G SIM card work in a Nokia Lumia 530 (a 3G mobile phone)?
Re: Will Plusnet 4G SIM work in a Nokia Lumia 530 (3G mobile phone)?
19-01-2017 6:57 PM
Hi MAW,
As the Nokia in question was released in 2014, it would not be able to support 4G I'm afraid.
You can take a look at the handset and it's capabilities here if you'd like to know more:
http://www.gsmarena.com/nokia_lumia_530-6523.php
Any other questions, just ask
19-01-2017 7:08 PM
Would this phone still work in 3G mode with this 4G SIM?
19-01-2017 7:20 PM
19-01-2017 7:28 PM
I shall give it a go - many thanks
05-05-2017 3:16 PM
will the 4g work with my apple iphone 3g please?
05-05-2017 3:34 PM
Plusnet/EE network uses 2G, 3G and 4G so any phone able to use at least one of those 3 systems will work.
Example a 4G phone can use the PN 2G, 3G and 4G but a 3G phone can only use 3G and 2G while a 2G phone can only use 2G.
When it comes to data a 3G phone will be slower to download/ display web pages and download data be it apps or file than a 4G phone but calls and text will be the same on any of the systems.
on
05-05-2017
9:11 PM
- last edited on
05-05-2017
9:13 PM
by
Mav
Thanks very much for the info, I rarely go on the internet with the phone, just a few texts & calls a month that's all I need, paying £10 a month at the mo.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
06-05-2017 11:11 AM
You might be better off by using a PAYG SIM from the likes of 3 if you really don't make a lot of calls or text. I use their PAYG as the costs are worth it to me. and the credit does not expire, just top up a few times a year at £10 a go. Spent less than £50 in the last 2 years.
Basically it is 3p a minute for calls, 2p a text and 1p per MB of data
- Mobile
