Wi-fi calling
- Mobile
- Wi-fi calling
Wi-fi calling
26-09-2022 1:39 PM
Question is does Plusnet Mobile support Wi-Fi calling in conjunction with Plusnet Broadband or not?
Re: Wi-fi calling
26-09-2022 1:44 PM
Plusnet mobile does not support Wi-Fi calling - whoever your ISP is.
Re: Wi-fi calling
26-09-2022 1:48 PM
Re: Wi-fi calling
26-09-2022 1:49 PM
No idea - and they won't tell you until - or if - they do.
Re: Wi-fi calling
26-09-2022 1:52 PM
As @jab1 says they wont tell you until they did. However as people have been asking for this since Plusnet Mobile launched last decade, I wouldn't hold your breath waiting.
Re: Wi-fi calling
07-10-2022 8:54 AM
I also need this, living in an area without any mobile signal coverage. Looking on the Plusnet FAQ, I noticed there is a Wi-Fi calling section, https://www.plus.net/help/mobile/wi-ficalling which suggests a different 4G SIM may be required. On calling Plusnet though it seems this is not yet available and the guy I spoke to had no idea when it was likely to appear, and was not willing to try and find out more.
So, it looks like its (finally) on its way, but I'm not sure if my patience will extend much longer
Re: Wi-fi calling
07-10-2022 9:11 AM
Hmm, I'm not sure that page is supposed to be there 😕🤐
Re: Wi-fi calling
07-10-2022 9:44 AM
I am sure you a right - has there been any suggestion when the product will be available that you know of?
Re: Wi-fi calling
07-10-2022 10:12 AM
Re: Wi-fi calling
07-10-2022 10:45 AM
Thanks - I'll find someone else
Re: Wi-fi calling
26-02-2023 11:32 AM
I recently called Plusnet to cancel my mobile deal because Plusnet does not support wi-fi calling. I was told that wi-fi calling is being introduced by Plusnet in March/April this year. So I postponed my cancellation. Now waiting developments.
Re: Wi-fi calling
28-02-2023 10:13 AM
Ended up going to 1p mobile - they are on EE network, £36 per year (unlimited calls/texts but only 250Mb data) and Wifi calling works a treat.
Re: Wi-fi calling
28-02-2023 10:35 AM
Yes, I have that 1p 12 months "deal". It's a no brainer if 250mb/month is sufficient and EE is the preferred network. I just switch off mobile data because I fortunately don't need it. Equivalent to £3/month. WiFi Calling too.🤐
