Voicemail not working
FIXED- Subscribe to RSS Feed
- Mobile
- Voicemail not working
22-09-2017 2:26 PM
Hi
I'm not sure if anyone else has encountered this issue. I can ring 555 and access my voicemail and settings etc. However, when someone rings my mobile and I do not answer, it doesn't even kick in with the option for them to leave a voicemail, it just rings off.
Is there something I'm not doing in the set-up?
Jo
Fixed! Go to the fix.
23-09-2017 8:47 AM
Try the following from @RebekaPreston
If you input the code **004*+447870020555*11*30# OR **004*07870020555*11*30# depending on your handset into your dial screen, this should enable your service.
Re: Voicemail not working
25-09-2017 10:59 AM
That's great! Thanks very much, all working now
