Voicemail greeting message
ShaunR5
Hi, i used my voicemail for the first time today and it made me record my own greeting message. Id like this returned to the standard default plusnet message. Is this possible? After a search on the forum i found a couple of numbers you could input into the handset which should return it to default but these havent worked for me.
Thanks in advance
1 REPLY
Fixes: 6
Re: Voicemail greeting message
Hi @ShaunR5,
thanks for getting in touch!
If you drop me a private message we can look into getting this reset for you.
 Sarah Stewart
