Voicemail erroneous service.
FIXEDTopic Options
- Mobile
- Voicemail erroneous service.
26-02-2020 6:11 PM
All of a sudden I'm unable to retrieve voicemail messages from the handset with original Plusnet sim in it.
some silly message 'trusted number or landline' when using Plusnet sim.
i believe I changed pin recently when prompted and have retrieved messages from your Plusnet sim as I don't use remote access.
Now, this is going to cause a nuisance as I can't listen to important messages!
Fixed! Go to the fix.
Message 1 of 2
(610 Views)
1 REPLY 1
26-02-2020 6:38 PM
Had brainwave - Phone (outgoing calls) was on 'ID withheld' so that's the crunch of issue.
Message 2 of 2
(603 Views)
