Voicemail Menu map guide
rich63
Plusnet,
It would be really useful if you supplied a menu map of the voicemail system that we could download.
One thing I couldn't find very easily was a way to check what message I had recorded(I've since disabled my voicemail because I found the verbal voice menu confusing).
RebekaPreston
All Star
Fixes: 31
Re: Voicemail Menu map guide
Hi rich63,
Thanks for getting in touch with us. I do apologise if you found the Voicemail service confusing, this is certainly something we don't want our customers experiencing when using the service and not what we aim for here at Plusnet mobile.
I'll be sure to take on board your suggestion and feed this back to the relevant department who can can look into this further.
In the meantime, if there's anything you need, don't hesitate to get in touch and we'll be more than happy to help!
- Rebeka Smiley
 Rebeka Preston
rich63
Thanks. What was missing was the option:
To listen to your recorded message please press 1{listen to message}, To accept this message please press 1, to rerecord a new message please press 2.  To record type [2] message press 3, to record type [3] message press 4.
This should be both as a separate menu option and when recording new message.
