Voicemail Icon remains on Phone Notification
- Mobile
- Voicemail Icon remains on Phone Notification
30-01-2017 1:33 PM
I have recently joined Plusnet. I continuously get the voicemail icon on my android phone even though there are no messages and even had my voicemail turned off by Plusnet. This has still not cured the problem. I have spoken to my phone manufacturer who suggest to factory reset my phone, which I did, but no success. Only way is to clear the data within the phone app., but to do this everytime I switch on the phone is a bore! Is there any advise to fix this. I have called Plusnet numerous time and they cant provide any fixes.
Re: Voicemail Icon remains on Phone Notification
31-01-2017 9:49 AM
Hi @amcnie,
Thanks for getting in touch. I'm sorry to hear the inconvenience caused regarding your Voicemail icon.
Just to clarify, what handset are you currently using? Once you've confirmed, I'll try my hardest to provide you with the best information possible for the settings of your handset. -Ashleigh
31-01-2017 9:52 AM
Would be great if you could advise how to reset network on my phone.
31-01-2017 10:36 AM
Hi amcnie,
Ashleigh is away from her desk at the moment so I'll pick this up for her. There is something you can try to remove this voicemail notification, although this advice is not direct from us, other users online have found this information to be useful and it has appeared to have worked for them.
You can try the following:
- Long-press on the notification and you should get a little "app info" box. Hit that, then hit "force stop". If the app info box doesn't appear, go into Settings -> Application Manager -> All, find the Phone app, and force stop it.
Users have also advised that under the "force stop" tab, there is a check box which says "show notifications", make sure that this isn't ticked.
If this doesn't work for you, send me a PM and I'll be able to look into this further.
- Rebeka
20-02-2017 5:13 PM
I have the same issue with a Galaxy S5
21-02-2017 7:58 AM
01-03-2017 3:08 PM
hmmmm seems not. What steps do I take?
01-03-2017 3:12 PM
Hi evtilsley,
If you could send me a private message, I can look into this further for you.
- Rebeka
14-10-2017 6:43 PM
I have the same problem i am using an LG G3 Cheers Ray
08-02-2018 11:47 AM
i have this problem too on a sony z5 esp annoying as I have a smartwatch and constantly get notifications I have tried al the below to fix without sucess
- Mobile
