Visual voicemail
- Mobile
- Visual voicemail
Visual voicemail
23-12-2021 3:31 PM
So I changed my sim to plusnet but now my visual voicemail has disappeared. Does plusnet not have a visual voicemail on December 2021 if they do how do I enable it?
Message 1 of 2
(1,373 Views)
1 REPLY 1
Re: Visual voicemail
23-12-2021 4:59 PM
Plusnet do not support Visual Voicemail. AFAIK only EE support it.
As a budget provider Plusnet also do not support WiFi calling, dialling short codes (so you may be unable to reply to your bank if you receive a text message querying a transaction) and do not use all the frequencies that EE use.
If you do a search of this forum you will find that Plusnet appear to have no intention of changing any of these shortcomings.
Message 2 of 2
(1,354 Views)
