Using plusnet mobile in Jersey
pyeomans
We are travelling to Jersey in September and wondering if we can use the mobile thee as we do here in the uk?
Do we need to set roaming on or anything?
Thanks.
4 REPLIES 4
Alex
Fixes: 13
Re: Using plusnet mobile in Jersey
Yes I went there years ago, I'd imagine you will need roaming enabled as Jersey does not use the standard UK networks.
HPsauce
Jersey isn't in the EU so chances are it's full international call rates to/from almost anywhere, but I'd check the Plusnet web site?
Protech
Jersey is a roam like home destination👍
I visited a few years back and had no problems using plusnet roaming
You can check out but you can never leave ( easily)
RichardB
Champion
Fixes: 34
Jersey is on the roam like at home list:
https://www.plus.net/help/mobile/roam-like-at-home/
