Using in Croatia
- Mobile
- Using in Croatia
Using in Croatia
26-09-2019 3:37 PM
Hi
I have just tried the live chat but they are useless
I am travelling to Croatia for 5 days next month, I have a very basic cheap package how do I prevent charges outside my usual? (I have a cap on allowing no excess)
thanks in advance
Re: Using in Croatia
26-09-2019 4:18 PM
26-09-2019 4:41 PM
Croatia is part of the EU and so you should be able to 'roam like at home'
Calls and texts to any EU destination ( including the uk ) will come out of your normal allowances. Dat usage will also come from your normal allowance. If you have set your smart cap to zero then once your allowance has been used you will not be able to make further calls , texts or use data
26-09-2019 4:57 PM
ty
