Using BT wifi extender with Plusnet
chopperaddict
I may well be asking the impossible BUT I would very much like to be able to use the pretty extensive BT WiFi coverage across the country with my tablet, which only has WiFi connectivity (no phone in there !)
I cannot seem to find any direct info on how I can do this, or even if I can, but as Plusnet is actually owned by BT, I assume that Plusnet customers should have access to this WIFi system ?Huh
Please don't shout at me if I am totally out of order Thumbs_Up
Ian
2 REPLIES 2
Mustrum
Fixes: 75
Re: Using BT wifi extender with Plusnet
You are not out of order, just wrong in your thinking.
If you want to use BT WiFi, you will need to either join BT or but a package from BTWiFi here .
chopperaddict
Thanks for that answer, I suspoected it would mean paying out more money, but thats life these days, sadly.
Ian
