Upgrading phone staying on Plusnet Mobile
shalom2010
Very simple question.
I have a Samsung S9 and will be upgrading in the future to a new Samsung phone, which takes the same type of sim card.
Do I simply transfer the sim to my new phone and the plusnet sim will work (as now) ?? (Without any other intervention)
4 REPLIES 4
Legend
Fixes: 245
Re: Upgrading phone staying on Plusnet Mobile
Simple answer - yes.
shalom2010
Simple reply...Thanks 😊
Mustrum
Fixes: 76
Or the more complicated answer if you also want to transfer your data and apps.
https://www.samsung.com/uk/support/mobile-devices/how-do-i-switch-my-android-device/
shalom2010
Thanks, knew that. The Plusnet Mobile faq has always been unclear on my simple query. Now clear.
