Unusual "plusnet" sign-in notification on phone
- Mobile
- Unusual "plusnet" sign-in notification on phone
04-04-2019 7:45 AM
Thanks,
Dave
Re: Unusual "plusnet" sign-in notification on phone
04-04-2019 8:10 AM
04-04-2019 8:32 AM
@davebiffuk, does that phone also have a Plusnet Mobile SIM in it? From what @Pjj00 says it sounds more on the mobile side of things than the broadband.
I've just switched mine to use only mobile data and it is working correctly with that, so it doesn't seem to be affecting everyone.
04-04-2019 8:39 AM
04-04-2019 8:47 AM
I don't usually reply to Fibre/mobile threads, but the link the OP put up looks horribly suspicious to me - I ain't clicking it to check, but I would be very cautious.
04-04-2019 8:51 AM - edited 04-04-2019 8:58 AM
I clicked on the link
BT Domain Management Centre
This domain has been registered by British Telecommunications plc.
Only two scripts running in the background, one is for google analytics the other is a wall of text
04-04-2019 8:54 AM
I ran a whois on the domain first and saw it was registered to BT before clicking on it
04-04-2019 9:00 AM
04-04-2019 9:06 AM - edited 04-04-2019 9:09 AM
Well it says in the tab it says 'BT DNS management', in the URL it says 'ISP Age Verification blocking'
might have something to do with this
04-04-2019 9:32 AM
Moderators Note
This topic has been moved from Fibre to Mobile as it seems to be a mobile related issue.
04-04-2019 9:57 AM
@Menace65 wrote:might have something to do with this
Suspect you're right
@davebiffuk just to clarify, you have a Plusnet SIM in the phone yes?
@Pjj00 is this happening on your mobile data connection, or are you also connected to Wi-Fi? Do you have Plusnet broadband too?
04-04-2019 10:46 AM
04-04-2019 11:01 AM
Thanks. Sorry, just noticed you'd already stated this in an earlier reply. Just looking for some clarity on which network is generating the behaviour i.e. Mobile or Broadband.
In a way, hoping @Pjj00 doesn't have Plusnet broadband as that would give us a clear indicator.
04-04-2019 1:28 PM - edited 04-04-2019 1:30 PM
"This site can’t be reached
The web page at http://www.ukisppageverificationblocking.co.uk/ might be temporarily down or it may have moved permanently to a new web address."
05-04-2019 12:55 AM
Appreciate the clarification folks. Turns out there was a network-related change early yesterday morning that may have caused some hiccups. Should be OK now, so shout if you notice anything untoward again.
- Mobile
