Unable to make/receive call while in Bulgaria
- Mobile
- Unable to make/receive call while in Bulgaria
11-04-2019 7:54 AM
Re: Unable to make/receive call while in Bulgaria
11-04-2019 10:50 AM
Hi @gordon152, thanks for getting in touch.
I am sorry to hear you're having issues accessing your mobile service while in Bulgaria. While it's true that we cannot guarantee service when abroad due to factors such as not having full control of the signal strength, functionality with the masts and local network in that particular area, we'd be happy to check on the account that everything is set up for international usage. Could you please private message:
-your full name
-your full address including postcode
-your mobile number
Once you have private messaged those details, please do let us know via this public post.
Regards
11-04-2019 2:15 PM
11-04-2019 2:38 PM
Thanks for providing that information, @gordon152
I've located your account - just as a final piece of security, could you please provide characters 2&7 from your memorable place via a further PM?
You can send the PM to myself if that helps. Please let us know here once you've sent that across.
Best wishes
Dave
12-04-2019 5:00 AM
I have sent you a PM message
12-04-2019 10:38 AM
Thanks for confirming those details @gordon152. I am just running some checks and will respond to your PM shortly.
15-04-2019 4:06 PM
15-04-2019 4:34 PM
Hi @gordon152,
I'm sorry for any inconvenience that this issue is causing you. We do not have an agreement with Vivacom, I'm afraid. The two operators that we have agreements with in Bulgaria are:
Telenor Bulgaria
MobiTel AD Bulgaria
I would recommend that you try manually searching for networks again as it should be bringing up these networks for you.
The agreement that we have with overseas operators is limited and so we cannot guarantee service whilst you are abroad and we cannot request that they fix any problems (e.g. if there is a mast down in the local area.)
15-04-2019 4:59 PM
I never received welcome sms when landed if this hepls. Not sure about Plusnet roaming agreements in Bulgaria as the network I am connected to is displayed as Vivacom BG(EE). Next I am pretty much constantly on the move so mast coverage ie mast down should not be an issue. I have attempted manually to select to other mobile networks in Bulgaria ie Telenor and MobiTel. My phone say that I can't be connected and try later in my case so far 10 days of trying. Not sure what I am doing wrong?
15-04-2019 6:19 PM
Hi @gordon152,
I'm sorry to hear you've run into this issue and thanks for confirming the details you have done so far. One thing I haven't seen talked about in this thread so far is if you've been able to try using the SIM card in another phone to see if the same problem still occurs?
16-04-2019 4:18 PM
16-04-2019 5:26 PM
Hi @gordon152,
I'm really sorry to hear that none of our checks so far have resolved the issue you're experiencing. I'd like to raise this and pass it along to our Mobile Ops team for further investigation at this stage, but before I can do so we'll need 3 examples of times you haven't been able to use your services.
Using the following format, please advise of 3 separate occasions you haven't been able to make/receive calls ranging at least 2 hours between each individual example provided.
Example 1
Date:
Time:
Service Attempted:
Phone Number (if applicable):
Error that occurred:
Network Roaming on:
Please send this information across on a private message to myself and we'll pick this back up for further review as soon as possible.
- Mobile
