Unable to disable Voicemail
winelight
When I try to disable Voicemail I can see the current settings but when I try to change them I get "Network or SIM card error" and my changes don't stick. There is no network or SIM card error, of course, and everything else works fine. Yes I have removed cleaned and reinserted the SIM, and I have checked the network status, and I have waited a week and tried again.
Tags (1)
4 REPLIES 4
Longliner
Seasoned Pro
Fixes: 7
Re: Unable to disable Voicemail
I had same problem a few years back; didn't want voicemail because we have a nuisance-blocking answering machine. At that time I was told to phone Pnet tech support as it was not possible online. A long wait as usual but very helpful when I did get through.
Fixes: 1,577
Thanks for getting in touch.
I'm sorry to see you're unable to disable your voicemail service, we'd be happy to carry this out from our side if you want.
Feel free to send me a PM with your full name, confirming you are the account holder, full address and your mobile number.
winelight
Thanks for both replies. I called support, it was answered immediately, and they did it there and then.
Fixes: 1,577
Glad to hear that! Thumbs_Up
Let us know if you need any further assistance.
