Unable to access 4G services whilst roaming
FIXED- Subscribe to RSS Feed
- Mobile
- Unable to access 4G services whilst roaming
Re: Unable to access 4G services whilst roaming
27-06-2022 9:53 AM
Hi @LaurenB
I have had the same problem last week whilst in France. I could only get 3G despite having a full signal (my partner had 4G via O2 with no problem). I have tried all the different options as described and no change. It was really frustrating and very slow to use my iPhone XR which is usually very quick. I had 4G as soon as I returned to the UK.
Are you able to include my trip and phone details so you can add to the investigation? If so how do I send them to you?
Thanks for your help.
27-06-2022 10:51 AM
27-06-2022 10:53 AM
Hi @adamwalker
Thanks - I will send 4 messages including this one!
27-06-2022 10:54 AM
Hi @adamwalker
Message 3 - I still have the issue
27-06-2022 10:55 AM
Message 4 - same issue!
27-06-2022 10:55 AM
Message 5 - Hopefully I will be given PM access now?
27-06-2022 1:03 PM
27-06-2022 1:11 PM
@skeg0 I think you might be what they have been looking for to progress this issue - someone who is actually actively having the problem right now. You need to make a couple more random forum replies so you can DM the admins here with your details. Hopefully this leads to them fixing it!
Paging @Gandalf @adamwalker FYI
27-06-2022 1:12 PM
@hokers Thanks, it seems that its a common issue across Europe from reading up on other posts!
27-06-2022 1:13 PM
post 3
27-06-2022 1:13 PM
post 4
27-06-2022 1:13 PM
post 5 - if that helps
27-06-2022 1:20 PM
27-06-2022 1:25 PM
I think you have to DM them directly
https://community.plus.net/t5/notes/privatenotespage/tab/compose/note-to-user-id/45633
With this data:
Account ref/mobile number:
Dates you were away: (IMPORTANT TO TELL THEM YOU HAVE THE PROBLEM RIGHT NOW)
Issue that occurred:
Make and model of handset:
Software version:
They will probably do some security checks via DM
ref: INC000001180539
27-06-2022 1:29 PM
- Mobile
