Trying to send a text to France from the UK.
SammyT
I'm trying to text a friend in France to make sure we can contact each other. I'm using the +33 and have the correct number (They appear on Whatsapp)
But my text is failing to send.
Any help would be appreciated.
6 REPLIES 6
198kHz
Fixes: 39
Re: Trying to send a text to France from the UK.
Welcome to the forum.  🙂
Does your friend have a French mobile number, or is he 'roaming' with a UK number?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
SammyT
French number.
198kHz
Fixes: 39
OK, thought it best to check that first.
Assuming you're omitting the leading '0' of his number, I'm afraid I've nothing else to suggest, other than waiting for a Help Team member to spot this topic and respond.  🤞
Smith7
Seasoned Pro
The cost to text a French mobile is 6p I think.
Have you set your Smart Cap to zero if so it won't send
You will need to set your Smart Cap to £1or so
Fixes: 1,577
Hi @SammyT
Are you texting them or messaging on WhatsApp?
SammyT
Texting
