Transferring my number
JL8682
I need to transfer my number from Plusnet for work reasons. Rather than close the account i want to transfer my sons mobile number to my Plusnet account. I have been told that this isn't possible because as soon as i transfer my number the account will be closed - is this correct? Thanks
2 REPLIES 2
Fixes: 400
Re: Transferring my number
@JL8682 Welcome to the forum.
Cant you just transfer your phone number to the new operator and let your account with Plusnet close. Having done that open a new Plusnet  account and transfer your son's number to that?
Are you overcomplicating and confusing the issue by trying to do this in one operation?
Mads
Fixes: 79
@JL8682
That's correct, as soon as your number is transferred out your account will close. I'd suggest as @Baldrick1 has and just transfer out your number, allow the account to close and then just set up a new one for your son.
Thanks.
