Tethering with an Alcatel Pixi 3
ChuftSoFar
Re: Tethering with an Alcatel Pixi 3
Thanks Sayit for bringing this topic back to life, I completely forgot about it.
To quote what MisterW just posted:
Sometimes adding the 'dun' option to the APN type will work. If not then use the 2nd option in colin_maybe's link above. I.e the settings put global tether_dun_required 0
I can confirm this works on an Alcatel Pixi3 and also on a ZTE Blade A110, both unrooted phones. Thank you. Cool_smiley
Fixes: 393
DUN and done! Such a simple answer thank you!
@Sayit happy that the simple option worked.Smiley TBH I've not had great success with that option, it usually needs the 'settings' fix. I must admit,  I tried the DUN option on my new phone recently and it didn't work, I had to do the settings fix.
Why couldn't plusnet tell me that on the phone...
I can't really answer that, I would have expected them to be able to suggest the DUN optionRoll_eyes I wouldn't have expected them to suggest the settings option as that is Android specific and does require USB debugging.
Colin_Maybe
Fixes: 8
To save a bit of searching for anyone who needs this the original post by chrisl300 (who posted the original link and deserves the thanks) is here:
https://community.plus.net/t5/Mobile/Tethering/m-p/1445580/highlight/true#M4472
The link to the instructions (which Chris replicates in hs post) are here:
https://forum.xda-developers.com/z3/general/lollipop-tethering-t3058923
The links to the quick install ADB shell for PC needed (a lot simpler than it sounds) are here:
https://forum.xda-developers.com/showthread.php?t=2588979
