Tethering my laptop to my phone
vcpuk
I am unable to use mobile hot spot with my laptop.
Has anyone any tips please?
13 REPLIES 13
Smith7
Seasoned Pro
Re: Tethering my laptop to my phone
What problems are you having ?
Hope this helps
On your phone open up the data connection
Open up the Hotspot you will be given a name of the Hotspot connection eg Android AP4157 and a password make a note of them
Look on your laptop for available network connections click onto it and connect using  password
The laptop should save it for next time you need to use it
vcpuk
Thank you for responding so quickly.
When I click to connect it just comes up with unable to connect.
Am I missing something obvious?
Legend
Fixes: 254
Does your mobile phone network permit tethering - a number of them don't?
Smith7
Seasoned Pro
In the bottom LHS of your laptop in the search box type WiFi  setting the WiFi should be switched on
vcpuk
I can connect to other wifi networks, that is why I am confused.
Legend
Fixes: 254
@vcpuk Connecting to other networks (in cafes/shops?) is different to tethering, and as I have said, some mobile providers do not permit it. Have you checked if yours does?
Smith7
Seasoned Pro
I would have thought if the phone gives you a WiFi address and password it should connect
What network do you use for you mobile phone ?
vcpuk
Smith7
Seasoned Pro
Should work no problem I never had a problem
Does the data work on the phone check the APN setting
If still no joy call PN from your phone 500 and ask them
https://www.plus.net/help/mobile/mobile-phone-and-voicemail-settings/
vcpuk
Thank you very much for your help.
I appreciate your time and effort.
Does not make sense.
Smith7
Seasoned Pro
Me neither that's what we do try to help
Hope you get it sorted looks like you have tried everything
Champnet
Aspiring Hero
Fixes: 12
@vcpuk  Which make of mobile ?
Have you tried scanning Wi-Fi networks on your laptop ?
The mobile's network name may not be the same as the one you're expecting to see..
Mr_Paul
Seasoned Pro
Fixes: 11
@vcpuk
JooI, have you tried restarting your phone?
It can resolve a lot of problems easily!
