Testing reception before signing up?
FIXED- Subscribe to RSS Feed
- Mobile
- Testing reception before signing up?
29-11-2016 12:35 PM - edited 29-11-2016 12:55 PM
I am tempted by the new PlusNet Mobile offering but before I commit my money (even if it is just a fiver) I would like to test out what reception is going to be like here out in the sticks. Is there any way to do this? Can I order a free SIM and activate it (and pay the first month's contract) after it has been received/tested like with other providers? Alternatively, can I cancel the contract without penalty should I discover that signal reception is inadequate?
I suppose I could get a free EE SIM but I'd rather not go round the houses like that, and besides which I wouldn't want to fall foul of any service differences that might exist between the MVNO and underlying operator.
Fixed! Go to the fix.
Re: Testing reception before signing up?
29-11-2016 12:40 PM
They are all 30-day contracts; so if you go for the cheapest £5 deal, you're not committed to anything beyond 30 days
29-11-2016 12:41 PM
I've lost my £5 though!
29-11-2016 12:47 PM
29-11-2016 12:51 PM
It's not looking great for me either - fine outdoors but not inside. If the generic maps are touch-and-go the only real way of knowing is to actually try it.
29-11-2016 12:53 PM - edited 29-11-2016 12:58 PM
Checked for my location and it is all down as likely to have good coverage and I don't - it is typically one bar or less indoors for voice calls on EE (actually Virgin Mobile PAYG)
The EE Coverage checker is rather more accurate and pessimistic http://ee.co.uk/why-ee/mobile-coverage
29-11-2016 12:58 PM
Well as you may (or may not) know you need to take with a large pinch of salt what any mobile phone 'signal strength' indicator says, as any two phone can and will give different results.
29-11-2016 1:15 PM
Oldjim wrote: "The EE Coverage checker is rather more accurate and pessimistic http://ee.co.uk/why-ee/mobile-coverage"
No difference for me - but whether I'd get 4G is debatable - it's rather marginal.
29-11-2016 1:42 PM
If you were wanting to check the signal you can always use the EE website to check your postcode, as we'd supply the same signal as them, however if your still not sure you can always cancel the SIM within the 14 Day Return Period. If this was done you would receive a refund for the services not used, for example if no services were used you would be eligible for the full refund, but if you used half the services you'd be eligible for a refund of half of the monthly line rental.
You're able to cancel this contract without any penalty due to it being a 30 day rolling contract, so all we ask is 30 days notice before closing the account. Hope this helps.
29-11-2016 1:45 PM
Using the Plusnet checker my results seem fairly accurate
29-11-2016 1:51 PM
Hi @Oldjim,
Thanks for that, I'd forgotten about the new Plusnet coverage checker! If anyone needs the link here it is - https://www.plus.net/mobile/coverage-checker/
29-11-2016 2:57 PM - edited 29-11-2016 3:00 PM
@EmilyMcAuliffe wrote:
Thanks for that Emily. There are too many variables for the Ofcom/EE/PN signal checker to be of use (particularly the Plusnet tool - it only shows likely outdoor strength!) and so I will go ahead and order on the basis of cancelling within the return period if need be. I won't need to use any voice/data - simply measuring the signal strength with the SIM in will suffice for my needs.
29-11-2016 9:44 PM
Coverage checkers are only a general guide to the area you're in. They can't know if (for instance) your house has 6 foot thick walls and built in the shadow of a giant gasometer. Joking aside, my signal strength varies considerably between my house and the shops barely 400 meters away.
- Mobile
