Switch from PN to EE from Australia - PAC code abroad
martindavies
I've just moved to Australia for 15 months and having to do this switch to EE. I've tried signing up via the discount codes which takes me to EE which then asks if I want to keep my number get a PAC code - can't do this abroad. Can't continue the registration.
How do I transfer to the EE £6/mo for 5Gb sim only plan from PN whilst keeping my phone number?
Can't phone any UK numbers as don't have international calls and roaming is crazy expensive. No online chat available that I've found and haven't found an email address. Plus I don't know if it's PN I need to talk to about this or EE...
Many thanks for any help!
27 REPLIES 27
willcutforth
Fixes: 99
Re: Switch from PN to EE from Australia - PAC code abroad
Afternoon @martindavies you've come to the right place to sort this out! I can get you one sorted but I just need to get the details so I shall drop into your DM to sort it,
 Will Cutforth
louispride
Hi @willcutforth.
I am experiencing the exact same issue and also want to switch to the same package.
Could you drop me a DM as well please.
adamwalker
Fixes: 221
Hi @louispride
I've just sent you a PM, please drop me a reply when you can.
 Adam Walker
janesaunders123
Hi Adam,
I am Louis’s mother.
Please can you private message me the details please.
Kind regards,
Jane
Fixes: 424
Unless something has changed that I'm not aware of, its not possible to switch networks whilst abroad. The new SIM card MUST register on the new UK network for the transfer to complete.
janesaunders123
I appreciate the feedback.
However, whilst my son is abroad, I am in the U.K.
So it is possible to switch his SIM card for him.
Kind regards,
Jane
Fixes: 424
Thanks for clarifying, it wasn't obvious from the previous posts that the SIM card was still in the UK.
BlackGrouse
Hi, I'm in the same boat. In Hong Kong until May. My phone is eSim compatible if that will work?
Thanks for any help
MatthewWheeler
Fixes: 481
Hi @BlackGrouse
As @MisterW has advised you'd need to be in the UK for the transfer to work
 Matthew Wheeler
BlackGrouse
Thanks, do you have any practical advice on how I can switch and keep my number please.
Fixes: 424
You will need to get the SIM back to the UK and get a friend or relative to insert it into a spare phone. Then request a PAC and initiate the transfer. Once the transfer is complete , then send the sim back to you.
BlackGrouse
Thanks. If a physical SIM is registered in the UK could an eSim then be used in HK?
Fixes: 424
You'd have to ask the new provider about that, PN never supported eSIM. However I doubt it would be possible, even if the new provider supported them,  since you would still need to activate the new eSim , for which I suspect it would need to be on the UK network ?
Andrew_S
I also need to get a PAC code and I am currently in Australia.
I would greatly appreciate it if you could contact me and offer some guidance.
Thank you very much.
Andrew
