Svalbard roaming
bobo29
Svalbard roaming
Does the inclusive roaming cover you in Svalbard, which is part of Norway?
I only ask because it mentions roaming is included in Norway, but it mentions the Aland Islands as a separate place which belong to Finland and the Canary Islands which belong to Spain.
2 REPLIES 2
Mr_Paul
Fixes: 10
Re: Svalbard roaming
I think that the Aland and Canary Islands are both autonomous regions within their respective countries - a bit like the Channel Islands' and Isle of Man's relationship with the rest of the United Kingdom - so may explain why they are listed separately?
AFAIK, Svalbard is actually part of Norway?
EmilyD
Fixes: 117
Hi @bob29. I’m so sorry for how long it’s taken to get back to you! We’re quite busy right now, so it’s taking longer than we’d usually like to get back to customers.
I can confirm that, as Svalbard is classed as part of Norway, it'll be covered under Roam Like at Home. Please let me know if you have any further questions.
 Emily D
