Sudden high mobile data use
TFO89
I typically use 3-4 Gb data a month but over the last 48 hours my usage has rocketed from 2.5 Gb to 5 Gb.
When I look on Android at which apps are using data, the top one is only 300 Mb and pretty quickly they fall off to <100 Mb, certainly they don't add up to 5 Gb, any idea what could be causing this?
1 REPLY 1
Gel
Aspiring Champion
Fixes: 29
Re: Sudden high mobile data use
