Silent voicemail messages
PodPie
I’ve had voicemail set up for a while and have been able to listen to new messages in the past but now I get a notification but the message is silent when I try to listen to it. I’m using 555 and this works fine - I’m told there’s a new message and the time it was left... but there is nothing when the message plays. Can you please help?
12 REPLIES 12
OllieC
Fixes: 46
Re: Silent voicemail messages
Hi @PodPie
I'm sorry to hear about your voicemail issues.
Can you please confirm if you have called your own mobile and left a voicemail?
If you are able to leave a voicemail and hear it , it may be the people who called yourself with the issues.
Kind Regards
PodPie
Hi. Yes I have done that and I’ve also had messages that worked in the past. I can’t believe that coincidence would be so strong that everyone who left me a message had problems on their side! The issues have happened with personal mobiles, landlines and big business landlines so I can’t believe the problem lies anywhere other than with Plusnet.
Any other ideas?
Mads
Fixes: 79
Hi there @PodPie,
Thanks for letting us know.
Could you try the sim in another handset and let us know how you get on? If your messages still do not work, please pop over a PM with the following info:
- Your full name
- Your full address with postcode
- Your Plusnet mobile number
Thank you.
Kershnazzle
I'm also having this problem, one in every few messages is completely silent.  All from different people.
Voicemail is also sometimes incredibly slow, so a few seconds pause between every prompt
"Message received"
long pause
"at"
long pause
"3.50"
long pause
"on the"
you get the idea.  Very annoying.  I know when it was because i have a missed call, I just want to listen to it.  Even more annoying if I go through that whole process and then it's silent.
abails0105
Fixes: 60
Hi @Kershnazzle, thanks for getting in touch.
I am sorry you're experiencing issues with your voicemail. Have you been able to try your sim in a different handset? Can you also try re-booting your handset. You can do this by:
  • Turn the handset off
  • Take the SIM card out
  • Leave it for a couple of minutes
  • Replace the SIM card
  • Turn the handset back on again
Let us know how you get on
 Alice Baillie
Kershnazzle
I've done that, but there's no way of telling whether it's worked.  It sounds more like a software problem than a hardware one anyway.  I had already tried rebooting the phone, just taken the the SIM card out.
abails0105
Fixes: 60
Thanks for your response @Kershnazzle
So we can look into the account in further detail for you, could you please private message:
-Mobile number in question
-Full name and account name if different from yours,
-Full address including postcode.
Once you have sent a PM with those details, could you let us know via this public post?
Regards
 Alice Baillie
Kershnazzle
done Smiley
LaurenB
Fixes: 131
Thanks @Kershnazzle, I've picked this up and I've sent you a private message. Again, can you please drop us a message on here once you have replied to the PM.
 Lauren Barry
Kershnazzle
Seems a bit convoluted, having to leave a message to say I've sent a message?
Kershnazzle
...which incidentally I have done
SammyM
Fixes: 84
Hello @ Kershnazzle,
Thanks for getting back to us here, I have responded to your private message with the next steps we would like to take. I am in all weekend and would be happy to communicate via private message to make it easier, as well as keep everything in one place.
 Sammy M - Sheffield Team
