Should number transfer immediately ?
markpt44
Submitted my PAC Friday, and my old network as dropped an hour ago.
Put in Plusnet SIM and working, but showing the Plusnet number, not my ported EE number - how long should it typically take to port the number?
I was under the impression it would be immediate, and not ideal for work (or lack of!) contact ?!
1 REPLY 1
Fixes: 1,552
Re: Should number transfer immediately ?
Thanks for the post @markpt44 and apologies for the delayed response.
I'm sorry to see you had some downtime while we were transferring your number across. From what I can see I PM'd you a help article Here before putting the port through, which explains there may be some downtime.
Looking at your other posts, I understand you've had further issues and you've cancelled so I'd like to wish you all the best with whoever you've decided to go with next.
