Short code numbers
rogerwilson
Short code numbers
Hello,
I've just ported to PN from the 3 network. I can no longer RECEIVE text messages from the bank, doctor and others that use the short code format.
In Settings on my phone I've:
Manually selected the PN network
Cleared the cache of Messages
Reset Access point names
Nothing's made a difference. Any suggestions anyone before I go back to 3? Thanks in advance.
Roger.
12 REPLIES 12
Smith7
Seasoned Pro
Re: Short code numbers
Unfortunately Plusnet Mobile do not allow you to reply to short text codes there are many posts on this Forum about it.
You can receive them but not reply to them
If you need them you will have to go back to Three
To check your setting see below
 https://www.plus.net/help/mobile/mobile-phone-and-voicemail-settings/
rogerwilson
As I said, I cannot RECEIVE them.
Smith7
Seasoned Pro
I can but not reply back
Time to change if you need them I think it should be advised when you sign up
It's like everything in life you get what you pay for or don't get
Anoush
Aspiring Hero
Fixes: 139
Thanks for signing up @rogerwilson
I’m really sorry to see you’re having issues receiving short-code text messages. What’s the make and model of your phone handset, and do you have another handset you can try your SIM in, just to rule things out?
@Smith7, I think Roger’s issue is that he can’t receive short-code text messages when he should be able to. I don’t believe whether you can receive would bear relevance as it’d be a different account and possibly a different handset as well with its own settings. Smiley
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
rogerwilson
Yes I've tried the SIM in another handset and it's exactly the same - texts from other mobiles could be received but not 2 factor authentication messages from a short code number.
My phone is a Moto G7 Play.
Thanks,
Roger.
Fixes: 1,552
Hi Roger, I believe we've spoken via private message, but let me know if you need any further help. Smiley
Cheers
rogerwilson
Hi Anoush,
Really frustratingly, over the weekend a whole glut of previously undelivered short code texts arrived together. It looks like something happened behind the scenes to clear the fault. If I'd have known it was going to be fixed, I wouldn't have switched to Virgin Mobile! However that switch has just gone through today (and everything seems to work) so it's all a bit too late.
Thanks again for looking into this for me. The PN Customer Services just had a check list to go through which was never going to make any difference. In fact I was originally told PN doesn't support short codes at all! Only later after internet research did I find out it was only replying to them that isn't supported.
All the best,
Roger.
Fixes: 1,552
Hi Roger,
Ah terrible timing. Sad I'm not aware though of a problem or anything we've done behind the scenes to fix, so it's a mystery.
All the best with Virgin Mobile! Let me know if there's ever anything else you'd need help with.
Cheers
Smith7
Seasoned Pro
 But you CAN receive them  like I said
rogerwilson
There was a fault.
The fault was I couldn't receive short code texts.
OK?
enlliserve
Oh dear. Virgin Mobile have a 20 month long thread on their forum of some people having problems receiving short codes.
rogerwilson
So it's a known problem on UK mobile networks then. Thought so!
Luckily I'm all OK on Virgin. No problems at all.
Thanks for your contribution.
