Samsung s8 has not voicemail notification
All Star
Fixes: 31
Re: Samsung s8 has not voicemail notification
Hi bnichlsn,
I'm sorry for any confusion caused.
You're more than welcome to suggest and post any information or solutions that you think may help however, the staff are unable to suggest certain apps due to the possibility of this not working or causing damage to the customers phone.
- Rebeka Smiley
 Rebeka Preston
Rebeka,
  Thanks for the clarification. If YOU didn't remove my reply to Potiti, who did? Was it the Moderator? Should I post my reply again?
All Star
Fixes: 31
Hi bnichlsn,
We don't have the access to remove posts from the board. I can see your initial reply however, I'm not sure if you replied after this?
If so and it has been removed, I would advise to contact the moderators for more information. Although, they do normally advise when a post has been removed and the reasons why.
- Rebeka
 Rebeka Preston
Fixes: 423
Moderator's note by Mike (Mav): Two posts released from Spam Filter. The duplicate has been removed and the original appears here.
Forum Moderator and Customer
Thanks for the links to Better Voicemail. Unfortunately even the paid app seems to of disappeared. I've tried similar apps but they either don't work or will not work with this carrier. Has anyone found another voicemail notification app that works on this network?
