Samsung Smart Watch LTE
TudorBlue
Hi, im with another provider atm, Ive just got a Samsung galaxy smart watch. Its the LTE version, would i need to take out an extra mobile contract? Or if I joined plusnet could i use the same number?
4 REPLIES 4
enlliserve
Re: Samsung Smart Watch LTE
If you want to use it separate from your phone you will need a network that can supply a suitable eSIM. That used to be EE and Vodafone, but another of the main networks may have come on board
Plusnet is an MNVO and like others of its ilk does not support this.
Check with Samsung which UK networks support the watch in LTE mode
john4434
I rang this morning they do not do Esims also you cannot connect your watch to the network I have the same watch as you, I think only O2 im not sure about any other.
regards,
John Brooke
Apprentice
enlliserve
The list is out of date as Virgin have stopped doing eSIMs. Three have reintroduced them
