SMS to failing to send
samo
Hi
Over the last couple of days every sms I've tried to send has failed first time but it sends sucessfully when I retry.
Anyone else seen this issue?
Regards
Samo
1 REPLY 1
RebekaPreston
Fixes: 31
Re: SMS to failing to send
Hi samo,
Thanks for getting in touch with us!
We're not aware of any issues that could be causing this however, you can always re-boot your handset to see if this helps:
  • Turn the handset off
  • Take the SIM card out
  • Leave it for a couple of minutes
  • Replace the SIM card
  • Turn the handset back on again
It's important to remove the SIM from the handset entirely, so that it can disconnect and establish a new connection to the network upon re-boot.
You can also pop over to https://myaccount.ee.co.uk/networkchecker/checkservice, input your postcode and check for any issues/maintenance works in your area that could be affecting this.
- Rebeka
