SIM replacement
Emm1
SIM replacement
Hello, I just got a new phone, but my SIM card is too big. I need a nano SIM, is there any wat this could be sent to me or do I need to phone in and try to arrange for a new SIM card?
Thank you
18 REPLIES 18
Fixes: 411
Re: SIM replacement
@Emm1  Welcome to the forum.
If you have a relatively new SIM it will be a 3 in 1 type. Take your SIM card out you should find that it is perforated for smaller SIMs and all that you need to do is push the smaller SIM out of the centre.
Emm1
Re: SIM replacement
Hello, thanks for the reply, unfortunately it's not the 3 in 1 type, I've had my old phone for a number of years now and the SIM is too big, there's no way in making it fit.
Alex
Fixes: 13
Re: SIM replacement
I'm sure PlusNet can send a replacement.
In the meantime, you can try the old scissors trick and see if that works.
LaurenB
Fixes: 131
Re: SIM replacement
Hiya @Emm1, I'm sorry your SIM doesn't fit in the new handset. Could you pop me over a PM with your full name and Mobile number, and I can certainly assist with getting a new one sent for you.
(to send a PM, click on my name and then to the right, there will be a grey button to 'send private message' and in the message please include a link to this thread)
 Lauren Barry
thorpemeister
Re: SIM replacement
I would also like to order a new SIM. Can I message one of the Help team please?
Fixes: 1,596
Re: SIM replacement
Sure, just message me your mobile number and full name but you might need to post twice more first
thorpemeister
Re: SIM replacement
Thanks. Will do
thorpemeister
Re: SIM replacement
Hoping another post will unlock PM access
Fixes: 1,596
Re: SIM replacement
Yep it has done
thorpemeister
Re: SIM replacement
Thanks. I've sent you a PM
Recathi
Re: SIM replacement
I have lost my SIM chip, could I also have a replacement for that, please?
adamwalker
Fixes: 220
Re: SIM replacement
Hi @Recathi, can you send me a PM with your mobile number and your full name please?
 Adam Walker
Recathi
Re: SIM replacement
I'm trying, but access to private messages is still blocked for me.
Recathi
Re: SIM replacement
It seems I need to post more to unlock
