SIM package geared to data rather than voice
cjags
Fixes: 4
In order to get lots of data, I have to have unlimited text and calls.  Are there any plans for a data only package (or high data with low text and voice)?
2 REPLIES 2
OliGaffney
Fixes: 7
Re: SIM package geared to data rather than voice
Hi @cjags!
The full range of SIM deals we do can always be found here: https://www.plus.net/mobile/plans/sim-only/
I understand there may not currently be one which is ideal for you, but our special offers at the top of the page do change frequently so you can keep an eye out!
We can change your plan at any point once you have found one you like!
Thank you
-Oli
cjags
Fixes: 4
 That's a good idea.  My data usage does vary so I can flip between packages.
