Roaming with Movistar over limit
Efan
I'm from the UK on holiday in Spain, but the cap isn't working. I've gone 6GB over the limit and don't know how much it will cost! Can someone tell me?
3 REPLIES 3
brookheather
Re: Roaming with Movistar over limit
£1 per 10MB or £600 for 6GB though should be capped at £40.
BT FTTP 500 + pfSense + Uniquiti Unifi 6 Pro
Fixes: 421
@Efan
It shouldn’t exceed any Smart Cap limit that you have set in your account.
When you say that this is not working are you now locked out? It could be just a timing issue.
MatthewWheeler
Fixes: 481
Afternoon @Efan
I'm sorry to hear this has happened.
I'll drop you a PM shortly with some further questions so I can look into this for you
 Matthew Wheeler
