Roaming in Tenerife
Antonio75
Roaming in Tenerife
Hi there, it's my first day in Tenerife and roaming like at home doesn't work at all. Is this normal?
1 REPLY 1
adamwalker
Fixes: 221
Re: Roaming in Tenerife
Hi Antonio, I hope you're having a great time in Tenerife and I'm sorry roaming isn't working for you. The Canary's are covered by our roam like at home scheme so it should be OK: https://www.plus.net/help/mobile/roam-like-at-home/
I've sent you a PM, please reply back with the details I've asked for when you can and I'll look into the issue for you.
Adam
 Adam Walker
