Roaming in Australia
dom54
UK Resident travelling in AUS. Although I have more than £30 in my smart cap, I cannot access internet and GPS outside of a wifi. 4G not working. Can anyone help me with this? Obviously 4/5G access is a basic requirement when travelling outside of a wifi range. Thank you
3 REPLIES 3
Fixes: 421
Re: Roaming in Australia
@dom54
Did you switch data off before you arrived in Australia? Data is £6/MB. Yes, that's £6,000/GB. Your phone can get through your smart cap just booting up before getting to the instruction to switch off data. See https://www.plus.net/help/mobile/roaming-and-international-calls/
Get a local SIM card.
greygit1
Or locally 'rent' something like a EE minihub. Which can then provision up to four devices.
(Theis was brought to you by someone who went to Japan and had the same experience).
dom54
It was a little late to learn that I should have switch data off before arriving in AUS and useful to advise on buying a SIIM card which has solved the problem. It would be useful if PlusNet were upfront about there inability to offer full services outside of the EU (as seems to be the case). This would help travelling customers to be plan... thank you for your response.
